It is currently Sun Jul 13, 2025 2:32 am
 Post subject: Side thickness Question
PostPosted: Sun Feb 21, 2010 9:33 pm
First name: Big
Last Name: Jim
I have a back and sides set that I have bought . The sides are NOT same thickness , however with the equipment I have i am afriad to try and sand the one to match .
One side is .112 the other is .125 so about 13 tho thicker.
If you were building which side would you use for base side , treble side ?
Or is 13 thou really anything i need to be concerned with ??
PostPosted: Sun Feb 21, 2010 10:09 pm
Last Name: A
Wouldn't you want to thin these both to around .080 or .085" - I imagine bending something .11 or .125 would be pretty tough and heavy in the final product.
PostPosted: Mon Feb 22, 2010 7:20 am
1) Depends on the wood. I most always use maple (not sugar) that is quartered, soft, and really soak it in HOT water for an hour.
2) I size it to 3.2mm (1/8" or so).
3) Bend it on a very hot electric bender with a SS strap.
4) Depends on the radius you want to achieve.
On tough woods like Pink Ivory or rosewoods, I have boiled the wood for an hour and then clamped it in the mould. You have about 2 minutes to get it clamped. It's got to be quartered.
I have never been concerned with heavy in a mandolin. A few grams on the ribs doesn't make any difference. Most folks that build mandolins use thinner ribs, believing they can't be bent at 1/8" Not true as the photo shows...
PostPosted: Tue Mar 02, 2010 7:31 am
Haans - So can you tell me more about mandolin sides? Over on the guitar side, the radii are gentler and the sides generally much thinner. I assumed that thickness was at least partly dictated by bending necessity. Obviously not. Is there a reason you'd want thicker sides on a mandolin than a guitar? I suppose with the size, thicker sides would be really heavy on a guitar. What else?
Mike Lindstrom
PostPosted: Tue Mar 02, 2010 9:31 am
Mike, I like thick rims. I think guitars are thinner for three reasons. Most woods are stiffer and harder to bend, and they are way deeper. The third is that it is a lot harder to bind an F style mandolin, and you end up taking some off the rim to even it all out.
PostPosted: Thu Mar 04, 2010 3:39 pm
Haans... oh no... your longest side doesn't taper into the next side at the right end of that point.. you'll 'never' be able to sell that one. I hope this is just a practice model and your regular practice! The F5F's will never accept that practice. beehive (second f is for fanatic). ;)
Chris Oliver
Infinity Luthiers
...in the shop.
live every minute...
PostPosted: Fri Mar 05, 2010 6:31 am
First name: Deen
Last Name: smith
City: New York
State: New York
Zip/Postal Code: 10001
hello friends, I enjoy reading, walking, outdoor team sports, alternative medicine and listening to music.
digestrol
PostPosted: Tue Mar 09, 2010 10:18 am
Dean, I have a feeling if guitar sides were boiled they would bend much easier and could be a lot thicker, BUT, then you have to deal with wavy sides. That is why they are bent practically dry.
